Steering box from an '80: Metric or Standard Line Fittings??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5thatShmobs, Mar 24, 2003.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Steering box from an \'80: Metric or Standard Line Fittings??
    Is a steering box from an '80 2WD going to have metric or standard line fittings? Im looking for one to bolt into my '89 K5. I believe I need metric.
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    Re: Steering box from an \'80: Metric or Standard Line Fittings??
    my K10 has/had english
  3. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Which would be the equivalent of metric or standard... Im not sure which one English is.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    If the pumps are metric they say metric on the pump housing near the shaft under the pulley. /forums/images/graemlins/thumb.gif
  5. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    So if the "pump" says metric than the "box" will always be metric as well?
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I am sorry, I thought you said pump not box, but yes, if the pump and box are from the same year and the pump says metric then the box is also. I do believe that the "80" steering box is metric. Look into the hole where the fitting for the hose goes, if you see an invert flare fitting for the hose to seal against then it is not metric, if there is not a invert for the hose then it is metric and uses O-rings on the hose fitting to seal.
  7. NAUBlazer
    NAUBlazer Registered Member
    Dec 3, 2002
    18
    Chandler, AZ
    I just replaced my pump this week and i couldn't find a wrench that did fit, metric or standard. I just used a pair of vise grips to get on it. Ofcourse i had another line because that vise grip will eat it up. Thats what i did.
    Adam
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    From what I've read and heard, ALL boxes from '80 on up are metric O-ring ports. /forums/images/graemlins/thumb.gif
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    79 was last of american ones :P
