Steering box going out?
Discussion in 'The Garage' started by BranndonC, Jan 14, 2004.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    today while driving i noticed my truck wouldnt turn left unless forced past a binging point but turned right fine, i pulled over to see what was wrong, and it turns fine now ????
    i didnt do anything when i pulled over, it was like i tried turning left when the tires were against a curb, but when i give a small amount of "umph" to the turn, it passed the bind and turned fine
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    You just changed the pump so I would say it is just air in the system. /forums/images/graemlins/thinking.gif
  3. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    oh yeah, i just changed the pump. i forgot to mention that /forums/images/graemlins/wink.gif how do i get air out of the system?
  4. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Search /forums/images/graemlins/ignore.gif it has been posted before.
    just jack up the front of the truck and cycle the wheels slowly back and forth and make sure the fluid level is full
  5. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    ok sorry, search is my first thing i usually do, but i didnt know how to search for the problem, and once i found the solution, i didnt think to search, just ask how to fix it. /forums/images/graemlins/eek.gif /forums/images/graemlins/ignore.gif /forums/images/graemlins/thumb.gif
  6. Blaze
    Blaze 1/2 ton status
    Aug 28, 2000
    3,285
    Raleigh, NC
    My TA does the same thing and it is the steering box. Sucks too, it is a bitch to find a replacement WS6 steering box for a 79 TA. /forums/images/graemlins/frown.gif
  7. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    just messing with you, to bad you aren't a newbie. Or it would have been more like this:
    Search Newbie [​IMG]
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you can also use 82-92 third gen box, but you might have to swap line fittings, also there were two boxes,. the 605 and the 800, the 800 was reserved for Z28 and trans am and has larger pitman shaft diameter and so pitman arms will not interchange with the boxes. the 800 has bolted on pitman shaft cover and the 605 are not bolted on
    you can also use impala SS box, 67-69 F and A body boses too, etc, any that might be quicker ratio like ytour most likely is
