Steering box gurus...HELP!!
Discussion in 'The Garage' started by southernspeed, Jan 24, 2006.
  1. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I'm just drilling and tapping my box for hydro assist and like an IDIOT I let the input shaft fall out.
    I know have 6 black balls, 7 chrome balls and a worm gear sitting on my bench!
    How the heck do I put it back in????? Anyone?
  2. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I did a search for any tech articles about rebuilding Saginaw steering gear boxes, but I could not find any. rebuilding steering gear boxes must be one of those black arts that no one wants anybody else to know about.
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Thanks for trying! I've surfed google for ages looking but no luck. I'm pretty sure I can see how to do it and with some grease to hold them in place it should be easy enough....but if I'm wrong it'll be big! There's a lot of forces going on inside a steering box!
  4. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Dude! I did another search, and found a tech article on rebuilding steering gear boxes. It comes from PavementSucks.com. Here is the link...Sorry! after looking at this article closer, it only shows how to get a sector shaft out.
    http://www.pavementsucks.com/tech/steeringbox.php
  5. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Thanks for the effort! I guess no one else has been dumb enough to drop the input shaft out like me!!!
    The tech article prob got lost when the server crashed a couple of years ago.
  7. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,029
    1,347
    Kzoo, Mi
    Can you get your hands on a GM service manual? It should have that in it. If not I can look at mine if I can remember.
  8. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    I did that along time ago so I don't remember exactly, but you need to get some realy thick grease to hold the ball bearings to the shaft as you put it back in. Also the black ones and chrome ones are slightly different sizes and you need to alternate them: one chrome, one black, one chrome, and so on.
    Hope this helps.
    Brent
  9. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
  10. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Thanks for that but I'm a bit confused! I haven't got the box here at home with me so i could be talking outta my backside but when the 'piston' is in the bore of the box you can't get to the pipe and bolts to put the bearings in?
    Have I misread that post and what I'm supposed to do is put enough grease in to hold the bearings, put all the bearings in with the piston out of the box, remove worm gear then put the piston back in the box from one end then the worm gear from the other??/
    Sorry to seem a bit dumb but I can't work it out in my head!!
    Thanks.
  11. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Why were you messing with the input shaft anyways??
    :confused:
  12. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Well, you know....one minute it's sitting in the box, I turn the box over to try get all the filings out and bamm...tinkle tinkle...shaft and ball bearings on bench!
  13. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    but why did you pull out the front part of the box?
    All you need to do is stick a antenna magent in the holes to get the shavings out.
  14. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I didn't pull the front part untill the worm gear fell out the back. Then I thought i may as well clean the box properly. The front ain't a prob, it's getting the balls back in and the input shaft back in that's a problem!
  15. Stomper
    May 11, 2002
    3,767
    Iowa
    You're correct.....You'd have to pull the sector shaft to do it the way I said....Which isn't hard to do..
