Steering Box Help needed ASAP
Discussion in 'The Garage' started by cbbr, Jul 4, 2005.
  1. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I have a leak in the steering gearbox where the shafet connects at the top.
    I'm trying to replace the gasket in the top of the steering gearbox. I have the shaft off. How do you get the top of the gearbox open? Special tool.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
  3. cbbr
    Jul 17, 2004
    14,681
    Here's what I'm looking at. WTH????
  4. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    Steering seal
    You gotta take that rag joint off first, THEN you'll see the snap ring and the seal.
  5. cbbr
    Jul 17, 2004
    14,681
    How do you get the rag joint off? I've never worked on one of these before. It seems to be the story of my life, but I'm learning fast.
  6. LongIslander26
    Jun 25, 2005
    256
    Rag joint
    There should be a couple of bolts holding it on from the underside, just look under it, between it and the steering box, and you should see how it attaches.
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You can't just loosen the bolts on the clamp that holds the rag joint to the steering box. The bolts have to be completely removed. They fit into grooves in the shaft to provide a failsafe should the clamp get loose. :eek1:
  8. LongIslander26
    Jun 25, 2005
    256
    What he said!
    Yeah,and that too! :waytogo: :whistle:
  9. cbbr
    Jul 17, 2004
    14,681
    Thanks guys, I got the rag joint off. Now what?
  10. LongIslander26
    Jun 25, 2005
    256
    Next step
    You should see a snap ring that holds the seal in. Take that off and then get the seal out. Once it's out, look at the shaft and see if there's any crud or dried up P/S fluid on it, if there is you want to clean the shaft off first, usually a rag with some brake cleaner sprayed on it will do the trick. Wipe a little P/S fluid in the new seal, then put it all back together.
  11. cbbr
    Jul 17, 2004
    14,681
    Now I see it. Looks like I need snap ring pliers.
    Better Picture...
  12. LongIslander26
    Jun 25, 2005
    256
    Ok
    Ok, give me a minute to look something up.
  13. LongIslander26
    Jun 25, 2005
    256
    Snap ring
    According to the exploded diagrahm in my repair manual, there is a "Retaining ring" that holds the seal in. It's probaly one of those snap rings that doesn't have the holes on it for snap ring pliers, so you just need to get it out with a small screwdriver or something..
  14. LongIslander26
    Jun 25, 2005
    256
    snap ring
    There's the snap ring right there! The thing with the holes on the end of it!
  15. LongIslander26
    Jun 25, 2005
    256
    Good deal!
    Yeah, get the snap ring out, and then get the seal out. Don't worry about boogering up the seal, cause you're replacing it anyway. :waytogo:
  16. muscle
    muscle 1/2 ton status
    May 28, 2000
    408
    Show Low, AZ
    my steering box leaks too, is this pretty much the only replaceable seal?
  17. LongIslander26
    Jun 25, 2005
    256
    Only seal?
    There's another one where the pitman arm shaft comes out at the bottom, but it's a little more involved to get it out. I had my whole box apart about a year ago, and redid everything, but since it was awhile go, I'm a little rusty. This guy's digital camera sure saved the day! :waytogo: :woot:
  18. cbbr
    Jul 17, 2004
    14,681
    I've got it down to getting the seal out. Feel like your'e leading the blind yet?
    How do you get it out?
  19. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Tap it in on one side so it cocks itself in the bore , then pull it out with something or pry it out with something . Its easy , I did it .
  20. LongIslander26
    Jun 25, 2005
    256
    Yeah.
    What he said. By hook or by crook it needs to come out! :D
