Steering box info?
Discussion in 'The Garage' started by blazen91, Apr 13, 2004.
  1. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I have seen two different Chevy steering boxes. The only difference is the input shaft. One is larger than the other.
    QUESTION: What are the years or uses(by vehicle) for the different shafts so I can order the correct rebuild kit?
  2. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    I beleive the only difference is between 2WD and 4WD.
    4WD has the bolt that goes sideways through the pitman arm locating it onto the shaft.
    2WD has a nut at the end of the shaft to hold the pitman arm on.
  3. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Correct, but I need info on the input shaft, where the rag loint bolts to.
    The 4wd sector shaft has splines on 1/4 of with a bolt on the pitman arm. The 2wd shaft has slpines all the way around and has a nut on the end of it.
