steering box input valve?
Discussion in 'The Garage' started by Thumper, Jul 10, 2005.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I asked this in another thread, but never got any responses... maybe the title threw people off.
    In the input pressure fitting in the steering box, there is a little one way valve... lets fluid in from the pump, but not out. The box on mine was turning, but I wasnt getting any power assist. I pulled the guts out of the box and there was a little spring unravelled from the inside of that valve into the center body. I pulled it out, and now the little poppett valve in the fitting just floats around. I figure this is the issue, so I need to know if its replaceable or not. Or can I just drill out the hole a bit, remove the floating piece, and put it togather. How does that valve come out? Is it replaceable or do I have to get a new box?
    Mike
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I'm not sure about replacement. It's called a check valve, and I would call Matt at WTO, he's really knowledgable about the saginaw boxes.
