Steering box install question
Discussion in 'The Garage' started by 90K5, Dec 27, 2002.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Can I install my steering shaft with the box already bolted to the frame?
  2. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    I did but I have a 1" body lift and I had to persuade it a little with a big screwdriver...
    rene
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Does the shaft collapse at all? It looks like it can kind of telescope itself...
  4. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    I think it can...but how far I'm not sure. I know it extended a little with my 1" body lift so I wasn't too worried about trying to collapse it a little to bolt it back up.
    An alternative is to get one bolt started on the box and then rotate the box so you can attach the steering rod/rag joint...then finish bolting it up. I just did mine but my front clip wasn't on the truck so I'm sure it was much easier than what you're fighting!
    Rene
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    That sucks...i have it bolted up, torqued down, and locktited already
  6. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I think the steering shaft is designed to collapse in the event of an accident so the shaft doesn't end up stabbing you in the chest! /forums/images/graemlins/eek.gif Where the two parts of the shaft meet is a little hole with a plastic pin holding the two together. Try punching or pulling it out to be able to compress the shaft. It should work but its been a while since I messed with that.
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Yeah i saw that pin...we ended up takin the box off again so we could put locktite on the bolts, but thanks
