steering box noises???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by moneypit, Sep 3, 2000.
  1. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    I have a 86 Blaz w/new steeering box and it is making creeking noises. Would like to ditch it and go with something different that can handle the stress any suggestions on wich way to go??
  2. Heath-La. 89GMC
    Heath-La. 89GMC 1/2 ton status
    Feb 18, 2000
    134
    Monroe, Louisiana
    Are you sure its the steering box and not the frame under the box? My box started making screeching and popping noises and I looked and the box while somebody turned the wheel with the engine off. The whole box stared moving and the frame was busted. Ive heard of a lot of trucks doing that. Oh well, just a suggestion.
  3. moneypit
    Sep 3, 2000
    1,382
    COLORADO
    Thanx man I'll check it out tommorrow!!!!!
  4. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I've run into a few of the Chevy frames that are cracked around the steering gearbox. There are a couple of companies that sell reinforcement kits for $50-$60. A good investment for the extra safety factor.
  5. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
  6. stephan van leir
    stephan van leir 1/2 ton status
    May 4, 2000
    181
    central Colorado
    Your steering gear box is the strongest gear driven part on your truck! Hands down! They are powerful enough to break spring center pins, pretzel tie rods, crack hardened frames, and if your wheels are locked tightly in boulders, break sector shafts that make you axel shafts look small (yes, I learned the hard way).They will wear, but they will not break internaly. The sector shaft is the main weekness with the box. I`d bet that you have a frame, not a box problem.
  7. Heath-La. 89GMC
    Feb 18, 2000
    134
    Monroe, Louisiana
    I welded mine up after it busted. It cracked again a cuople of months later. The bolts that hold the sector on there were getting loose. I found that if I kept those bolts tight, especially the ones toward the front, It stayed ok. But, just be sure to keep em tight.
