Steering Box Or Other???
Discussion in 'The Garage' started by looloozu, Nov 4, 2006.
  1. looloozu
    looloozu Registered Member
    Oct 30, 2006
    26
    canada
    Ok so i have a 82 Blazer and i just got done installing the 4" suspension lift kit. And now the steering is a little sloppy. It was before the lift but now more so. Before I start spending $$$ on random parts what are some common things that will tighten the steering up?
  2. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    did you use any type of correction like a new steering arm on the axle? sloppy how?
  3. looloozu
    Oct 30, 2006
    26
    canada
    yes the new raiser arm was with the kit. its sloppy like i can turn the wheel 1/4 turn before she will steer in that direction. also i still have stock tires on. I can turn the wheel from side to side and the wheels will stay centered, it like i have play some place im just not sure were to start replacing. a friend said my steering box may be messed. i had the play before the lift but it wasnt as much.
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    You need to have someone turn the steering wheel while you look for the point at which stuff stops moving.
  5. looloozu
    Oct 30, 2006
    26
    canada
    what exactly am i looking for?? play around the steering arm??
  6. dremu
    Feb 27, 2000
    15,952
    443
    East of San Francisco
    Well, could be draglink ends, tierod ends, ragjoint, or the box, yeah.
    My experience is that the boxes lose power assist more than get sloppy, but ymmwv.
    Oh and check the u-bolts on the axle for tightness!
    As for slop, watch for where the movement stops when somebody turns the wheel ... does the rag joint turn on top of the box, but not the shaft it connects to? (Repalce rag joint.) Does the box move, but not the steering arm? (Box.) Does the draglink move, but not the arm? (Draglink ends) Does one wheel move, but not the other? (Tierod ends.)
    That kind of thing. You should see it, if it's as bad you describe.
    -- A
