steering box pouring out fluid...
Discussion in 'The Garage' started by BranndonC, Dec 8, 2005.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    cant get a pic but if this was a chevy box [​IMG] then it would be the aluminum colored box on the top left of the box thats leaking, i mean pouring out, i put fluid in and drive across the driveway and its out. can it just be re sealed? Or is the box bad?
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    It has a rubber o-ring in the top of it. It is really easy to change.
    Just pull of the pitman arm.
    the take off the 4 bolts that hold the aluminum cover on.
    Then just grab it and pull the whole sector shaft out.
    The o-ring goes in a groove in the bottom of the cover.
  3. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    thanks man, i'll do that saturday:D
  4. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Check it with a straight edge after you get it out. I've seen warped ones.
  5. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    will do, thanks
