steering box question
Discussion in 'The Garage' started by surpip, Jul 13, 2006.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    so i got my box out and tore apart
    man there was alot of crud in there
    anyway, how do i get the top cap off the sector shaft? and when i put it back together how do i set the preload on the shaft?
    the directions on the rebuild kit are kind vauge
    and any other tips i should know about, i am replacing the sector shaft seals, and the seal on the input shaft
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    To get the cap off of the sector shaft, remove the locknut in the center of the cap.
    Setting the pre-load is pretty easy if you have the right tools.
    The following adjustments must be made with drag link disconnected from pitman arm and flange removed from worm shaft.
    Loosen lock nut and turn lash adjuster screw all the way in (clockwise), then out (counterclockwise) three turns. This will remove load imposed on worm bearings by close meshing of rack and sector teeth.
    Using a socket on steering gear worm shaft, turn shaft from one stop all the way to the other carefully counting total number of turns.
    NOTE: Do not turn hard against stops when drag link is disconnected as damage to ball guides may result.
    Turn the shaft back one-half total number of turns to center position and using an inch-pound torque wrench, measure pull required to keep worm shaft in motion through center position. This should be 1-1/2 - 5-1/2 inch pounds. If indicated pull does not lie between given limits, make the following adjustments:
    a. Loosen lock nut
    b. Turn adjuster until required resistance to pull is reached.
    c. Tighten lock nut and recheck pull. It must lie between limits specified after lock nut is tightened.
    Note: Turn lash adjuster screw clockwise to remove lash and counter-clockwise to increase lash from gear teeth.
    Here is the only tip I have......Don't misplace the balls.....or install them wrong
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    If you're not replacing the sector shaft but just need to remove it to make changing seals easier just center the steering box and remove the 4 cover bolts and pull sector shaft out with cover still attached to it, doing it this way also does not affect the adjustment although the adjustment should still be re-checked upon re-assembly.
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    well its to late for that now, its out, i just couldent get the cap off the shaft
    im not sure i was to replace the inside stuff, but i may, just for peace of mind
    i just wish i had a step by step so i dont screw it up
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I sent you a PM - complete diagram.
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    sweet thanks man
  7. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    let me know what all is involved in replacing that input seal, I've got to do that soon, with the box still in the truck :deal:
  8. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    ok so the balls came out, is there any trick to get them back in?
  9. cbbr
    Jul 17, 2004
    14,681
    Pray. And alternate them. They go dark, shiny, dark, shiny. Use some grease to hold them all in the nut so you can turn the worm shaft back in.
  10. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    If you don't have the box completely apart at this point you now will have to take it apart to fix it. Ask me how i know. :D This is what ended up makig me figure out how to rebuild steering boxes and also made it much easier to drill and tap for hydro assist. I have since learned how to drill and tap without having to take the box apart, only the end cap and the input shaft need to come out. :thumb:
  11. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    ya its all apart
  12. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    well ****tty
    steering box one, dale 0!!
    rebuilding it was easy, but it just doesn't work, i think it was jacked up to begin with, the valve spool just didn't fit right, but oh well, ill order one tomorrow.
    putting the balls in was wicked easy, you just slide the shaft in, and put all the balls that will fit around the shaft,(wow, did i just say put the balls around the shaft? humm anyway) than you put the rest of the balls in the split "U" on hold the just the 2 at the tops of the u in with a little grease, and install the "U" took me like 5 min to do it all.
  13. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    The spool valve can be tricky, it likes to slip off the pin and not allow the input bearing housing to screw on all the way.
  14. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    the pin and the valve just wouldent line up right
  15. cbbr
    Jul 17, 2004
    14,681
    Did you ever get it right?
  16. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    nope no workey
    just gonna buy a new one
  17. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    I was gonna suggest that You just buy a new one from the get go, but it's much funnier to see You frustrated:D
  18. cbbr
    Jul 17, 2004
    14,681
    Welcome to the steering box losers club. I did the same thing. PITA.
  19. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    not frustrated, good learning experience
  20. Desert Yeti
    Desert Yeti 1/2 ton status
    Mar 20, 2003
    320
    Tucson, AZ
    would you mind sharing that diagram with me too? I don't yet have my box apart and after reading this I may just buy a new or reman one anyway, but I'll probably take a stab at rebuilding it first! Steering Box Losers Club here I come!
    Thanks!
