steering box question
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by rrent, Oct 20, 2001.
  1. rrent
    rrent 1/2 ton status
    Jun 10, 2001
    174
    Round Rock, Texas
    I'm needing a new steering box - mine is leaking and being the stock one - almost 30 years old. I'm not sure exactly what years will fit '73-'82? I'd like to get one from a local auto parts store after a quick price check.
    thanks in advance
    Ronnie
    '72 Blazer mostly stock original "Baby Poop" yellow color
  2. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    If you're getting one from a parts store, you should just tell them what year Blazer you have and let them figure out which one you need by using their parts books. IIRC, the parts store rebuilt boxes are pretty expensive and you might as well buy an AGR box for that kind of money.
  3. ErikH
    ErikH 1/2 ton status
    May 15, 2001
    112
    Southern California
    I just bought a rebuilt power-steering box from Autozone (with a lifetime warranty) for $160. I'm currently in the process of swapping out my manual steering system with a power one, and Autozone said they'll take my old gear box as a core exchange (also $160), even though it's not the same type of box.
  4. rrent
    Jun 10, 2001
    174
    Round Rock, Texas
    Very good - that's what I'm looking for. Did you ask for the correct year (i.e. '71-'72) I know sometimes when asking for such an old part you get that dazed look, and the obligatory "not in the computer" - unless you get lucky and the person behind the counter can and will look in an actual parts book.
  5. ErikH
    May 15, 2001
    112
    Southern California
    I pulled the brackets, pullies and apparently new hydraulic pump off a '75 K10 pickup at a local salvage yard (a very lucky find-- it even had front RS9000's, which I also bought... I should have also bought the rear 14-bolt FF). I then bought new hoses, belts, water pump, and gear box at Autozone. I confirmed with them that the gear box they sold fit both my '71(which their computers covered) and the '75. They're the same model. All together the swap should cost around $250. Not bad at all.
  6. jmeador74
    jmeador74 1/2 ton status
    Oct 31, 2001
    108
    Eatontown, NJ
    I hope you catch this reply...
    I just got through rebuilding my steering gear box last year for 55 dollars (rebuild kit) and I did it myself. I had to pay another 15 dollars for another gasket that was the real culprit. The top cover gasket where those four bolts are on top... Well the rebuild was tricky at first, but not real hard... I found out the hard way that a late model steering gear box will not work for you even though it looks the same because the fitting of the lines will be different... unless you get custom lines made specifically for you and that late model gear box... Hope this helps.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeap after 79 or 80 the hose fittings are O ring type and not flared !
    '72 K-5 4x4, CST, 3.07, 4 speed, NP 205, 31' x 10.5", converting to 2wd and pickup body(I did not want to do this- rust made me do it)
