steering box question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chris Demartini, Jan 26, 2001.
  1. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>I'm going to start gathering up the rest of the parts I need for crossover this week. I have 2 2WD steering boxes, how do I tell if the threads are metric or ASE? Also, does anyone have prices or part #'s for the ORD steering arm and stud kit? I cant find it on they're site. TIA</font color=blue>
    <font color=blue>pavement queen with shinny paint job and car tires</font color=blue>
  2. konajoe
    konajoe 1/2 ton status Premium Member
    Nov 15, 2000
    112
    7
    Massachusetts, U.S.A.
    biggray71,
    The easiest way to i.d. the difference is,
    The early standard thread box uses inverted flare to seal the fitting. Remove the fittings and when looking at the 2 ports on the box youll see a bevel facing upwards that is what the inverted flare fitting seats on.
    The later model metric box uses a special square cut o-ring to seal the fitting. The 2 ports are a straight shot in with just a small step for the oring to seal on.
    I'm not sure on the ORD stuff, so cant help ya there.
    Hope this helps, [​IMG]
    Konajoe
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>OK I'll check the flares tomorow. Somewhere in my garage is the 4WD box that came on my truck, it puked PS fluid two years ago so I changed it out. I'll try to dig that up tomorow and compare. thanks!</font color=blue>
