Steering box rebuild kit!
Discussion in 'The Garage' started by backyardbuilt, Jul 14, 2004.
  1. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    I have heard there is such a thing. My ? is who carries it, and does it come with the metal ring that hold the aluminum end cap in. Thanks
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I'd be interested in knowing too, especially if they make them for a 67-72 pickup.
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I have a complete box out of my 98. Ther sector shaft bushings are shot but if the end cap retaining ring is the same you can have it. Not too sure how you would find out if they are the same though
  4. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Napa has it...I've got one at home right now that I need to install. As for the ring, I'm not sure but I can check tonight /forums/images/graemlins/peace.gif
  5. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    The problem with the ring is getting it out you bend it all to hell.
    Stomper that would be cool if you could see if the ring comes with the kit. What is the part # for it.
  6. readymix
    May 30, 2004
    6,706
    26
    I got the ring out of mine last year by draining all the fluid and striking the end cap with a rubber mallet a few times. Then get the ring out with a scribe. It was pretty easy.
  7. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I am assuming you all are talking about the snap ring on the front parr of the box (round cap). The trick to it is the little 1/8" hole at the top. Rotate the ring around to that hole and use a small punch/pick to push the ring out of its groove. Then pry it out. I do hear ya on how easy it is to ruin that friggin thing though.
  8. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Thats the ring I'm talking about mine is screwed becuase the steering box had alot of undercoating sprayed on it, so I had to peel it out with a friend and we killed it. Can I get a new one.
  9. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    http://westtexasoffroad.homestead.com/index.html
    Give Matt a call. If there is a kit they will let you know, if not he can re-build it for you. I have dealt with them and have nothing but good things to say. Even if there isnt a kit and you dont want to pay for shipping yours he will talk to you if he isnt too busey.
  10. Stomper
    May 11, 2002
    3,767
    Iowa
    Ok, what I've got is a<font color="red"> "Stearing gear seal kit" Napa 7-182</font>. This is for a 85' c-10 box. The big ring you want IS in the kit, along with all the seals, snap rings, o-rings and washers. There are no bearings but unless the box has been full of water and they are rusted it shouldn't need them imo. Not exactly sure on price but I'm thinking it was in the $30 range. /forums/images/graemlins/crazy.gifAlso there is another kit, smaller, all it has is seals for the pitman arm.$14ish Got it the first time by mistake. /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
  11. readymix
    May 30, 2004
    6,706
    26
    If you want mine let me know and i will mail it out to you.
  12. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Stomper thanks for the info I will check with napa here and hope they have one in stock. Box worked great just a little leak, but I'm doing my hydro steering now and went with the drilled caps so need that kit. Thanks
  13. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Readymix since this kit should work I'll use it but thanks for the offer check the link in my sig I'll give ya a discount on something if ya need anything, if not thanks for the offer.
  14. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    If you haven't tapped the caps yet then you might want to check out this site. steering box tapping
    The problem I have now is that I can't get the rack piston and worm back together with the balls. I also have the kit from NAPA, was $36. It didn't show on the computer, they had to look it up in the book.
    Brett
  15. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Got the kit, it is the one. I already drilled tapped put the fittings in and everything. I'm not gonna rebuild the whole box just the end cap and the part where the steering shaft hooks up at. So far I have maybe 110$ in my hydro setup.Thats for everything ram, lines, fittings, rebuild kit, and mounts.
  16. 77fixer
    Nov 22, 2001
    464
    Meridian, ID 83646
    Where did you get your ram? Is it a 1.5 or 2"? What type of ends? I am having trouble finding one for cheap. All the agricultural rams I'm finding are 2" and I think that will be too slow for street driving.
    Brett
  17. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Mine is 2" with a 1.25" shaft 2500 psi from harbor frieght it has the 1" clevis ends. It is a big ram but should work just fine I have seen one in action and it didn't steer any slower than if it wasn't there. It was 49.99 I got there hoses and fittings with it all shipped for 75$.
  18. 77fixer
    Nov 22, 2001
    464
    Meridian, ID 83646
    I would like to see pictures when you get it done, just to see how the clevis ends look.
    I figured out my problems. I had two boxes apart and mixed some parts up.
  19. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    I will definetely post up some pics when its done (soon I hope). The pins for the clevis ends are 1" so my neighbor is gonna mill the holes in the 3/8ths plate I'm using for my mounts. I am gonna use thick walled pipe as spacers to fill in the difference on the width of the clevis. The mount for the axle is gonna be bolt on and I am looking into making the tie rod side bolt on to, just not to sure on how just yet, have some ideas though.
