steering box rebuild?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by four_by_ken, May 20, 2002.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Can a steering box be rebuilt, seals and such, while still on the truck, or does it have to be removed?
    Ken H.
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    From what I understand, you will have to remove it. And why not? you have to disconnect the steering shaft and the steering arm to get to all the components. I gotta think once you do all that, dropping it should be too tough. And rebuilding something like that on a workbench or garage floor where you can get it and you in any position needed may be MUCH easier than trying to do it under the rig.
    Just my 2 pennies.
  3. Ryan
    Ryan Registered Member
    Jan 17, 2001
    27
    Eastern NC
    I would remove it from the truck. It's not that hard. I have a factory service manual for several 70's era Oldsmobiles, that has the detailed rebuild instructions for a GM power steering pump and steering box. I believe all GM recirculationg ball power steering boxes were basically the same except for the ratio for many years until they went to that rack and pinion crap. If you would like a copy, send a PM.
