Steering box seal....? help
Discussion in 'The Garage' started by MOBK5, Sep 28, 2005.
  1. MOBK5
    MOBK5 1/2 ton status
    Apr 5, 2005
    180
    MCAS Cherry Point, NC
    Ok, my stock 82 k5 has a horrible steeringfluid leak. I have the stock push pull steering and a gm 10bolt front axle. All I need to know is if there is a seal in the back of the box where the shaft goes into it. The fluid looks like its coming from there because I already check the two hoses.
    Thanks in advance
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
  3. MOBK5
    Apr 5, 2005
    180
    served :(
    thanks cbbr
  4. cbbr
    Jul 17, 2004
    14,681
    No 'serve' intended - I had the same issue a while back and knew exactly where to look. :waytogo:
