Steering box swaps
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rcpilot, Feb 6, 2003.
  1. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    Will a '85 GMC 4wd steering box fit a '76 K5.. I checked wiht Kragen on line and they are different part #'s..
  2. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    I'm pretty sure the 85 will not fit the 76 the frames are too different. If I'm wrong someone will correct me I'm sure /forums/images/graemlins/grin.gif
    Eric /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  3. bee32
    bee32 1/2 ton status
    Aug 6, 2001
    401
    Virginia Beach Va.
    Can't answer it directly. Not enough knowlegde. But see if the bolt patterns are the same for mounting. Wish I could help more. Only thing I could come up with.Good Luck
  4. dyeager535
    26,978
    I'm thinking the box will bolt up, the difference is the threads on the box for the fluid lines, thats why the part # difference. You can swap the fitting on the back of the PS pump with a newer one, so you can run the newer hoses.
    The fitting on the newer ones is like the AC connections, with an o-ring, while the "old" ones were just flared.
    I guarantee someone knows for sure if it just bolts up, it's just too early in the morning /forums/images/graemlins/smile.gif
  5. limey
    limey 1/2 ton status
    Dec 17, 2002
    121
    midland texal
    in 79 through 80 they changed that threads on the pump and the gearbox if you change the gearbox you will have to change the pump and hoses aswell i think they will bolt up the same but dont quote me on that. they look the same with exception if the fittings. i gust payed 50 for a pre 79 pump, pbracket, pullys and belts because i didnt have any of them (i think i payed to much but o well) any ways hope that helps /forums/images/graemlins/rotfl.gif
  6. dyeager535
    26,978
    The fitting for the pressure hose on the back of the pump unthreads. You don't have to change the pump itself, just get the fitting of the correct style and swap it. Then you can run the newer hose with the new gear box.
  7. limey
    Dec 17, 2002
    121
    midland texal
    that would have bin nice to know o-well
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah box is same other than the hose ends style, that can be gotten around
    good luck
  9. mdm365
    mdm365 1/2 ton status
    Jul 2, 2001
    536
    mineral wells wv
    I changed mine from manual to power steering a year ago mine is a 77 and I went with a 1980 box and pump the only change is flared fittings to o-ring on the hoses,The threds also changed.the pump I got had the flared so I changed the valve in the back of the pump to match the o- ring hoses. /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif mike
