Steering box, what style?
Discussion in 'The Garage' started by ChevyCaGal, Feb 20, 2003.
  1. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I'm looking for a 2wd box to do crossover.... I was asked if one with flare fittings would work. I thought I had the o-ring style. Now I'm not sure and can't figure out what I will need for crossover? I am going to have this made hydro by WTO as soon as I get for what it matters... thanks!
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Which style you want depends entirely on which style PS pump you have, O-ring vs. flare.
    My 76 is flare. Not sure what the yeat cutoff is.
    You need to take a line, hi or low pressure, off the steering box and see if it has a flared end or if it has an o-ring.
    -- Mike
  3. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    For what it is worth, it's from a 86, and it's stock. I will have to check this weekend if there is no other way to tell...
  4. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Stock 86 is definitely an O ring style.
    -- Mike
  5. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Thank you. I couldn't find the exact answer in search. It pulled up like 500 items! /forums/images/graemlins/smile.gif
  6. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    What ever you do get the right pump for the right box---after the last steering box i broke i had to hurry and buy another and got the wrong one--i had to buy the right hose for the box, cut off the end and put the old pump end (basically making my own hose.)ended up costing me $40 for one hose when all said and done.
