Steering box year break?
Discussion in 'The Garage' started by 90blzr, Dec 8, 2003.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    What are the year breaks for the steering boxes? I know there are the early style and later...something about one using o-rings...I cant remember exactly though. /forums/images/graemlins/crazy.gif
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I think the break happened in the 80's but I am not sure sure. My 83 has an older style in it and it's original.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    68-79 and then 80-up
    and only because of the line fittings which is no big deal
    68-79 are normal 3/8 flare and then 80-up are crappy O-ring fittings style
  4. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    So then for a 1976 K5 we need to find one from 68-79 with power steering? Cool, thats what I needed to know/forums/images/graemlins/thumb.gif
  5. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    could you just change the fittings?
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    if you swap the fitting in back of the pump then you can use whichever hoses that have to be used with whatever year of box
  7. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    So if I find a gear box from a, hmmm...lets say '91 /forums/images/graemlins/smirk.gif K5, it would work if we got the fittings/lines off of the pump of the 91 also? Then just swap the gear box into the 76 and replace the fittings on the 76 pump and hook up the 1991 lines?
  8. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    My 80 has O-ring hoses. My 79 had no O-rings.
  9. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    sounds like it will work! /forums/images/graemlins/wink.gif
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    76/77 they changed the input spline size on the box
    so if you wish to retain your steering column(or just the shaft portion perhaps) you need 76 or older
  11. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    jsut make sure you buy box with rag joint intact then, i have swapped rag joint from like 81 ps to 68 manual and other swaps and never run across different size input, but yeah there is a another diameter of input shaft, but ive never had it happen to me in all the box swaps ive done over the years, ive donr swaps on 68, 71, 76, 78, 82 trucks so far that i know of, either swpaping one p/s for another or p/s to manual, or manual to p/s and the manual being 63-72 one.
    good luck
