Steering Box
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1979jimmy350, Apr 6, 2004.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    Is a steering box off of a 2 wheel drive and one off of a four wheel drive the same. Can a two wheel drive box be used in a four wheel drive truck
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    when doing cross over steering you need the 2wd box. don't think you can get the 4wd arm on the 2wd box.
  3. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    If I recall correctly the 4wd output shaft has two index's and the 2wd has 4 index's.. you can't use a 2wd box on a 4wd unless you converting to cross-over. The pitman arm won't index and it won't be lined up correctly.
