steering box
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by zforce, Apr 27, 2001.
  1. zforce
    zforce Newbie
    Mar 22, 2001
    3
    Wisconsin
    My 70' blazer has a lot of play in the steering. I think its the steering box that has most of the play. Does anyone now what years might fit to replace it?
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Have you tried adjusting it yet? There is an allen head screw with a jam nut on top of the box. It is easy to over tighten the box so be carful and make small turns untill most of the slop is gone. Also your rag joint may be warn....
    good luck
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  3. sean72
    sean72 Registered Member
    Feb 7, 2001
    34
    colorado
    my 72 Jimmy was doing the same thing, also getting worse and worse, I finally crawled under there last night and the whole steering box was loose, hand loose, after tightning it up it works great again..
  4. highwaydevil
    highwaydevil 1/2 ton status
    Oct 6, 2000
    145
    Colorado
    You might also check your rag joint. I replaced mine and it helped.
  5. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    What's a rag joint? That in the column?
  6. highwaydevil
    Oct 6, 2000
    145
    Colorado
    The rag joint is the rubber/cloth disc at the base of the upper column. (In between the joint for the column and the steering box.)
  7. 69AZBlazer
    69AZBlazer Registered Member
    Jan 31, 2001
    11
    Chandler, AZ
    What happens if you overtighten? Steering too hard or too loose?
  8. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    What the small adjuster on the top of the box does is adjust the gear lash. If you tighten it too much it will ware faster, be harder to steer, feel "lumpy", and could lock up in a turn. It is best to get the manual and do it right.
    The other thing that may need to be adjusted is the worm shaft bearings (the adjustment is just under the rag joint). You should adjust this first and than the gear lash. You need to disconnect the steering link (the tie rod that goes from the Pitman arm to the axle) and use an in-lb torque wrench (on the steering wheel nut) to measure the turning force (starting and continuous). The torque specks should be in the manual.
    '71 Blazer CST with alot of rust
