Steering box?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Flyinhi86, May 14, 2001.
  1. Flyinhi86
    Flyinhi86 Registered Member
    Mar 31, 2001
    51
    Ft McMurray, AB, Canada
    After reading many posts about cracking the frame around the steering box, I decided to check mine out. There doesn't seem to be any cracks on the frame, but the fluid resivour frame on the engine has cracked a couple of times. Would it be due to strain since put 35's on. I wasn't aware of the aftermarket brace. Anuy comments.
  2. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    The mount for the pump/reservoir is cracked?? How bizarre... Never heard of that happenin'.
    Why do people keep calling it a Bronco!!!!! [​IMG]
  3. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    If it's the bracket that holds the resivoir to the engine that's cracking maybe your belt is too tight. As far as the frame cracking I would put the brace in before the frame cracks. It's less trouble in the long run. Some friends and I have installed them and everyone has the same opinion. It helps, even on the pavement. Good luck.
