steering box?
Discussion in 'The Garage' started by kookydoright, Nov 3, 2005.
  1. kookydoright
    kookydoright Registered Member
    Nov 3, 2005
    16
    oklahoma
    i recently had my frame repaired around the steering box, now my steering box leaks. its not the lines, it seems to be where the shaft enters the box. all the fluid usually leaks out in about 30 minutes. any suggestions or help?
    thanks
    85 k10 swb, 350, 700r4, 208, 10/12 blt, 4" lift, 33 bfg's
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Was the steering box installed while the repair was made? Sounds like your Sector shaft seal. Thinking someone welded while the box was mounted and ruined it from the heat.
  3. kookydoright
    Nov 3, 2005
    16
    oklahoma
    how should i go about replacing the seal? anyone?
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
  5. kookydoright
    Nov 3, 2005
    16
    oklahoma
    thanks cbbr, sounds like im in the same situation you were in. i don't have alot on mechanic experience either, but im going to give it a shot. thanks!
  6. cbbr
    Jul 17, 2004
    14,681
    Mine started leaking again. Looks like it may be time for a replacement. Good luck.
  7. MOBK5
    MOBK5 1/2 ton status
    Apr 5, 2005
    180
    MCAS Cherry Point, NC
    Mine was doing that a couple of weeks ago. While trying to find the right seal, I learned I had a oddball box. Fricken sucked ass. Went to the stealership, payed them $40, got a c-clip, seal, and washer, put it all in, and the sonofabitch still leaked. Then I went and got the steering box of my parts blazer. Problem solved.
