Steering box
Discussion in 'The Garage' started by 4X4HIGH, Nov 3, 2005.
  1. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Ok, so i am about to embark on rebuilding a steering gear box and i need to install a 2WD sector shaft for my crossover steering and i need to know does the 2WD shaft have to be from a truck or is a car sector shaft the same?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I'm not positive on this, but I think I remember reading somewhere that a car is slightly different.
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Post up if you find a source for new ones. I've been trying with the help of MRK5 to get new but it looks like it's got to be used.
  4. sweetk30
    Nov 1, 2004
    25,544
    539
    horseheads , ny 14845
    just a simple question but why go threw all the hassle of shaft swap when you can just remove the bolts and hoses and swap the complet box? and all of this after you found the box.
  5. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    What Hassle :confused: I guarantee that swaping sector shafts out is quicker and easier to do. Pull pitman, unbolt top cap, remove, replace in same manner, done. No hoses, no rag jont to deal with, and you know the condition of your box vs. not knowing the condition of the JY box. I pulled the one from the JY with the box still on the frame and stuck it in mine w/o removing it either.
  6. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Ok, so now back to the original question. What does the 2WD shaft need to come from, truck or car or are they the same?
  7. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    did you hit up Eric M from the norcal board to see if he still had the one from that suburban?
    I bolted mine on last night. I swapped out the box so that I could get different fittings, since mine where the oring style.
  8. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Not true. If you don't set the drag to the correct amount of torque after swapping out the sector shaft, your gear mesh will be all out of whack. It can cause binding issues. Bad juju. Ask me how I know. :eek1: :doah:
    To answer your original question. It needs to be from a 2WD truck.
  9. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    yep chevy K series vehicles. can be either truck or blazer in the 2wd version.
    You will need to pull the steering shaft to set up the new shaft.
  10. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    so wouldnt that mean a "c" series vehicle?
    :D
  11. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    what about the 2wd suburban?
  12. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    C K there all the same :D
    yea Burbs, K5's, and truck will all work if there 2wd.
  13. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    C/K series only
    that means no S-series, or any cars
    they are reversed, wrong side of the frame rail
    and no G series either(vans)
    good luck
  14. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    Not to hijack, but while we are on the subject of tearing a steering gear box apart, does anybody know where to find a good tech article on rebuilding a Saginaw stearing box? Not just an article on swaping the sector shaft only, and not just a link to a post describing how to rebuild a box...I am talking a full tech article write-up with pictures and everything. I have spent about 2-hours searching the Internet for one, and I cannot find one any place.
  15. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Just look in a Chiltons or motors manual, that is where i got all my info when i rebuilt my steering box. The manual gives you all the required torque values and adjustment specs.
  16. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    I have a Chiltons, and there is only two sentences on steering boxes:
    Chapter 4) 4.23 "remove gear box"
    Chapter 4) 4.24 "to install gear box/reverse procedure found in 4.23".
  17. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    umm, "C" is 2wd
    "k" is 4x4...........(and for 88-91, "R" is 2wd, "V" is 4x4)
  18. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    umm
    yes C is 2wd and G also(from factory, although a few 4x4 G series exist, but rare)
    everyone knows this
    what, did i say that C was not 2wd ?
    id like you to show me where i did,
    i was just saying what boxes will bolt on the right side of the frame rail, the outer side
    C/K/R/V all do
    also 87 was R/V series,
    this started in 87
    my 87 c-10 was an R10
    i think you misunderstood what i posted up there
    i was not saying that C is 4x4
    or that it wasnt
    i was just talking about steering box design
    that S-series and G-series wont/cant work on a C/K(R/V) series
    if you want to get technical then we could talk about the 70-72 2wd K-5's(all 69 were 4x4)
    the designation letter wasnt always accurate with GM
    K wasnt always 4x4, for example
    but people can believe/think what they want, i try my best to help ppl, but you can only try so much, then its just time to give up, my problem is that i dont give up easily enough when i know that i am right and know what im talking about
    good luck
