Steering Box
Discussion in 'The Garage' started by 1978Blazerk5, Apr 25, 2007.
  1. 1978Blazerk5
    1978Blazerk5 1/2 ton status
    Aug 25, 2006
    2,158
    wisconsin
    Hey I have a 78 K5 there is alot of play in the steering wheel,i pretty much figure i need a new steering box. one of my friends said i should get a kwik-Ratio steering box.Is there any companies that make one? and what your opnion?
  2. socalslider
    socalslider Registered Member
    Jun 21, 2004
    71
    Oceanside Ca
    I had alot of play at the wheel, I repaced the drag link, now the truck is tight, I'd make sure it's the box before I'd replace it.
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    There's lots of things that cause play in our steering. The steering box is probably the least likley though.
    See here: Clicky
    And also remember, these trucks wern't super tight from the factory.
    GM had variable ratio boxes on 69-74 model trucks and the CUCV trucks also have.
    I've never heard of a company making a 4wd quick ratio box, that doesn't really make much sense for 4x4's. There may be some 2wd saginaw boxes out there that have quick ratio if that's really what you want.
  4. dsmd58
    dsmd58 1/2 ton status
    Sep 18, 2005
    624
    This is a great post..cause I have the same problem. What would cause the steering to not work properly until the truck is warm? It takes my rig about 2 minutes from when it starts up until the steering is responsive, could this be the power steering pump?
  5. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    That does sound more like a steering pump problem. That could also be a box problem. But I'd start with the pump. Check fluid, is there enough? Too much? Is it the right color, consistancy? Is it bubbling or frothing alot? Do you have hydroboost on your truck? Is the belt tight? Does the belt squeal at all?
  6. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    Mine was loose when I bought it, and I was told if I tightend an adjustment bolt on top of the box, that it would tighten it up?
    I've also read on here somewhere that sometimes everything related to the steering system needs to be tightend. And a steering box brace helps a lot too from what I hear. I plan on ordering mine this summer.
  7. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Tighting the allen bolt on the top of your box won't remove any play from the system.
    What it will do is place more pre-load on the sector shaft. (Requireing more effort from you to turn the wheel, more torque input from you that is).
    It will not remove play, that is not it's design. Additionally, if you overtighten that bolt, you can break the sector shaft over time, leaving you in a potentially very bad situation going down the road.
    I would avoid tightning that bolt.
    YOu would only be masking the symtoms slightly, if at all
    The ORD steering brace is an excellent upgrade, but it's more for preventing cracks in the frame than for reducing slop in the steering.
    The most likely candidates for slop is the drag link, the tie-rod and the collapsable steering shaft.
    Other high on the list are ball joints and wheel bearings.
