steering box ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazing86, Jun 30, 2002.
  1. blazing86
    blazing86 1/2 ton status
    Dec 24, 2000
    290
    how can i take the slop out of my steering box? Is it possible or do i need to get a new one. By the way this is on a 2wheel drive box.,
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    There should be a big nut on it with an allen head adjustment screw in the center. Hold the adjustment screw and loosen the lock nut, then turn the adjustment screw about 1/4 turn at a time. This should help.
    BTW, dont forget to tighten the lock nut when youre done!
  3. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    if you try adjusting do it when the box is turned to the center of it's travel. they are made to be tightest at center (when wheels are supposed to be straight) and you may see slight play when turned either side. if you adjust it when it's off center it will be too tight at center and may bind.
