steering brace and crossover
Discussion in 'The Garage' started by mostwanted, Mar 5, 2007.
  1. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    I just ordered a set of flat top knuckles from diy. I have been reading this thread: http://coloradok5.com/forums/showthread.php?t=200968&page=2 and I wanted to make sure I order the correct steering brace. If I run a 2wd steering box, will the 4wd brace fit correctly?
  2. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    the 2wd box and the 4wd box are the same, EXCEPT the sector shaft. that's all you need from a 2wd drive box for x-over.
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    As YZEATER says, the boxes are the same so you can just put a 2wd shaft in your 4wd box. I used aN ORD bolt in brace and was very happy with it.
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Your good. Make sure the rag joint fits the new box.
