Steering Brace: Remove existing 'L' Bracket?
Discussion in 'OffRoad Design' started by Little Giant, Mar 17, 2002.
  1. Little Giant
    Little Giant Registered Member
    Mar 3, 2002
    46
    Way up North
    Steering Brace: Remove existing \'L\' Bracket?
    Last night I installed my ORD steering box brace kit on my '84 K20. But I didn't follow the directions exactly, so I wanted to pose the question. Why do the directions say to remove the existing 'L' bracket between the frame and front of crossmember, <a target="_blank" href=http://coloradok5.com/ordsteeringbrace/ordsteer3.jpg>http://coloradok5.com/ordsteeringbrace/ordsteer3.jpg</a> rather than modify the bracket?
    At least on my truck that, that 'L' bracket tied a factory bumper bracket to the crossmember, it seemed like a worthwhile structural piece.
    What I did was remove that existing bracket, bolted the ORD forward bracket loosely to the steering box as shown in the write up, but the two factory crossmember bolts back on w/o the nuts, and figured out I only needed to take a little material off the original bracket in order to make it fit in front of the ORD bracket. So basically I slipped in the ORD forward bracket inbetween the original factory bracket and the crossmember.
    Now, am I missing something? Is this putting too much strain on the crossmember? Is there a reason why this is not typically done, should I remove the bracket as the directions state?
    Just curious. Thanks.
  2. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    Re: Steering Brace: Remove existing \'L\' Bracket?
    I did the exact same thing last night. It just took 10 min. to grind the hole into a oval. I was wondering the same thing, it seem's to be a better way. Might ask stephen at ord.
  3. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    u both did it right . i did it the same way and he said that there is nothing wrong with it .
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yup.
