Steering brace
Discussion in 'OffRoad Design' started by 85GMCJimmy, Jul 13, 2001.
  1. 85GMCJimmy
    85GMCJimmy Registered Member
    Feb 21, 2000
    83
    South Carolina
    Today i was looking under my Jimmy, by the way it is a 85 just for reference sake. I was looking of the center cross member, and there is some kind of brake valve of some type mounted about 2 to 3 inches to the left from the center of the center cross member, will the effect the mounting of the steering brace or will the brace go around the brake valve to bypass it. On Steve's he does not have that brake vale on his, he just has the hoses.
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    There should be a hole just above the p-valve. It needs to be enlarged to work with the bolt they send. You may have to bend the lines to clear it if it does hit, just don't kink the lines. i know BlazinOR has a pic or two on his page with the brace installed on his.
    <font color=red>It's not what you drive, but what drives you</font color=red>( Or is it what you work on,lol)
    <font color=orange> 1955 willy's on a 1977 blazer chassis </font color=orange>
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    It still cracks me up to hear someone say "I was out looking under my Jimmy....."
    I like to play with my Jimmy too, it's ok :-)
    The box brace should go over the brake lines and the prop valve. It has cutouts in it to clear most of the lines. Sometimes they require some re-routing (bending) but most of the time it doesn't take much to put it on.
    Making the world better, one truck at a time.
    [image][/image]
    SW-ORD
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    LOL!
    <a target="_blank" href=http://www.K5.rockcrawler.com>www.K5.rockcrawler.com</a>
    *<font color=red>under construction</font color=red>*
  5. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    Had to move my lines and also the bolt sent was not long enough to get a thread or two to show..
    The Few, The Proud, The K5 Blazer
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    With a nylock nut, you really don't need any poking out of the nut, the threads end before the nylon, so if they end up flush with the nylon, you're doing fine. If I remember right, that's about how they work out.
    Sounds like it went on OK.
    SW-ORD
  7. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    After I got through fondling my Jimmy, [​IMG]
    I had maybe 1 thread or 2 protruding through the nylon.
    there was a little bolt on bracket that secured the hard lines to the crossmeber, but I just removed the bracket, bent the lines up re-drilled the holes and secured the lines up above the brace.
    Did you say I have monkeys flying outta my butt?[​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
