Steering collumn swapping 88 standard to 90 Tilt Questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by foxman, Aug 6, 2003.
  1. foxman
    foxman 1/2 ton status
    Oct 22, 2001
    251
    Detroit MI
    Just got An 88 K5 off of Indianna88. I want to swap the regular steering collumn with the tilt collumn in my 90. Is it possible and how far down do i disconnect it? What about wiring? Should it be the same? And helpful hints/imput is appreciated. /forums/images/graemlins/ears.gif
    Thanks,
    Jeremy
  2. dyeager535
    26,980
    Disconnect it from the intermediate shaft in the engine bay. Then unbolt/unhook everything attached to it in the passenger compartment. It will come out fairly easy.
    Wiring is the only major issue, just make sure all the wires are the same. '88-90 should be, but with the '88 being standard, it may not have had some of the same wiring, like key in ignition buzzer, headlight warning, etc.
