steering coloum trouble
Discussion in 'The Garage' started by adamforsythe, Jun 13, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello my sterring coloum is getting really loose. How do tighten it back up?
    Adam
  2. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    if it's a tilt column:
    there are four male torx bolts, deep inside the column you need to remove, loc-tite and replace -- one at a time. you will probably need a steering wheel puller, lock-plate removal tool.
    i can give you more advise if needed.
  3. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    block the tires and do this on a level surace.
    i learned from my mistake.
  4. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    http://www.necoa.org/article95.html That link should give you pretty good step by step instructions.. It has a list of tools and things you will need... Hell it even has detailed pics :D Hope it helps..
  5. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Wow looks like a lot of work. I think I will make this a weekend job.
    Adam
