steering colum
Discussion in 'The Garage' started by crazytrain, Apr 28, 2007.
  1. crazytrain
    crazytrain Newbie
    Mar 2, 2007
    4
    indiana
    ?I have a 85 Jimmy that i've tightened the tilt wheel on twice:mad: . My question is will a truck colum inter-change with aJimmy?
  2. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    Yes. (assuming similar year of course).
    Also, stop using the steering wheel to pull yourself into the truck, install a handle if you really need to. Pulling on the wheel is what makes them go loose (took me a few vehicles to figure it out, now I never have problems)
  3. crazytrain
    crazytrain Newbie
    Mar 2, 2007
    4
    indiana
    say short bus ifailed to mention if it had to be out of a 4x4? thanks
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Loctite on those 4 torx screws in the base of the colum helps. ;)
  5. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    2WD, 4WD, doesn't matter.
    Watch out for different year stuff though, older stuff had a slightly different t/s connector, newer stuff has wiper on the column, etc..etc...
    Obviously there's manual and auto differences too...
    They will all bolt up and fit though.
  6. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    iirc, that wiring "break" year is 79 to 80 for the t/s connector...
    next sunday my 77 manual, no tilt column replaces my 87 POS... :D
