Steering Colum?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Tweetysuarus, Jan 26, 2004.
  1. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Is there an adjustment inside or outside to adjust the rod that enguages the power to the swithes? I've had ignition problems for sometime now and I'm getting frustrated as this is constantly cutting off! I have power to every accessory and vital componant in the rig but it just seems to shut down the ignition when it feels like it. Any susgestions or clue would be helpful please /forums/images/graemlins/confused.gif!
    Bill
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    could be the HEI control module
    does engine shut off if you barely twitch the ignition lock switch ?
  3. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    I've already replaced all that except for pick-up coil. I have a new Proform HEI sitting on the floor here, I'll install it as soon as my other half is better from surgery to where she can function on her own.
    Bill
  4. pineyjon
    pineyjon Registered Member
    Aug 23, 2003
    80
    south jersey
    is it a tilt column by any chance?
  5. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Yes, It's all tight no slop in the tilt.
    Bill
  6. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Have you replaced the ign switch itself? Not the lock cylinder but the ign switch on the column??? Connects to lock cyl via rod....
    DW
