Steering columb?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Triaged, Jan 20, 2002.
  1. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    While out wheel'n over new years my steeing wheel got real loose. I tore into it out on the trail (it was that bad and I had a hour to kill waiting for a friend) to see that the problem was that there was nothing holding pressure on the inner race of the bearing that supports the shaft. It seams that there would be some sort of nut there or something (all that was holding it was the plastic cancle cam/horn contact thing that kinda threaded onto the shaft). Is that what is suposed to hold it? Do I need to look for a large really fine thread nut (and than give up and make one)?
    BTW: it is the tilt columb and an auto.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  2. skyblazer
    skyblazer 1/2 ton status
    Oct 1, 2000
    209
    Houston, TX
    I just rebuilt my column a couple weeks ago. I believe you're talking about the upper column bearing. If I remember right, that bearing sits in a plastic race which is part of the turn signal/hazard light switch mechanism. This plastic piece bolts to the column body. When the steering shaft and wheel are assembled into the column, a spring on the bottom of the column puts pressure on the steering shaft which holds pressure against the upper and lower bearings, sandwiching everything together. My bottom bearing race is adjustable allowing the spring tension to be increased to eliminate shaft end-play. BTW this is on a column with no shift mechanism.
  3. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    If it's an original '69-'72 type tilt column, there is a wierd little 8-sided nut that holds a metal bearing race against the upper bearing. The spring thingy didn't happen until the columns with the steering interlock were introduced in '73.
  4. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I thought that was what was missing. All that was/is holding the preload on that bearing race is the plastic cancle cam/horn contact ring. It kinda threads onto the sahft.
    So where do I get a new Nut? The shaft has really fine threds (like 28 tpi) and is about 3/4" Dia.
    Now if I could only spell column right!
  5. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Back to the top.
    Does anyone know where I can get at nut?
  6. Steve_Chin
    Mar 6, 2001
    1,126
    I'd check in Hemmings Motor News for people who rebuild steering columns for '68 and earlier GM cars (since they are very similar columns).
  7. Dave_S
    Dave_S Registered Member
    Apr 11, 2001
    56
    Portland, OR
  8. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I guess there is no steel nut that holds the tension on that upper bearing. My part #9 is a bit different than the one LMC has. It is shorter and there is no spring. I checked the price in my cataolg (don't know why I didn't think of that???) and the part is only $0.45! Too bad they don't sell that spring that goes below it or the bearing. I will have to try and find a spring at a hardwear store or make a spacer to go where the spring should go.
    Thanks for all the help.
