Steering Column Adjustment????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by grtwhite, Sep 10, 2002.
  1. grtwhite
    grtwhite 1/2 ton status
    Aug 3, 2000
    366
    Macungie, PA
    I have just aquired a 77' 3/4 ton chevy pickup. After driving a blazer for years, the steering wheel seem awfully close to the driver. Is there anyway to adjust the length of the column to give the driver more room & to let you extend your arms a little? Thanks for your help!!!
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Sorry, the length of the column is fixed. However, many older GM columns are interchangable between the vehicles, so with a little research or junkyard scrounging, you may be able to find a shorter column in something else that you could swap in. </font color>
  3. grtwhite
    Aug 3, 2000
    366
    Macungie, PA
    Any idea of what vehicles had a shorter column?? Thanks for your help!
  4. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    how about a van.
    John
  5. dyeager535
    26,980
    You might try the mid-sizes, as in late 70's/80's Monte Carlo's, Cutlass', Regal, etc.
    Heck, they could even be longer! : )
  6. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    look for an 84 buick lesabre...I don't know if it fits or not but it has a telescoping wheel that moves in and out. If it did fit it would be very cool.
    just an idea.
    Chris
  7. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    maybe an aftermarket steering wheel would move it back to make it more comfortable for ya. Just an idea
  8. dyeager535
    26,980
    The cadillacs and corvettes got those too, but for some reason they don't work. I'm guessing length. My dad turned his truck column into a tilt/tele with Cadillac parts, but most of the stuff is from the truck column.
    IMO, the columns should have been telescopic from the factory, and not bothered with tilt.
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    van use old style mounting design like 67-72 trucks, major changes were made in 73 on trucks not on vans.
    cars all look to mount 90% same as 73-up trucks, i have a 79 de ville tilt telscope column and wheel i have never been able to even give away that i think i just may stick in the 79 K10 soon, hmmm
    i already know it will work, most any RWD 70's 80's car column will go in a 73-up truck
    good luck
  10. dyeager535
    26,980
    Don't forget also that GM changed the way the intermediate shaft clamped/bolted to the steering column. My dads '74 has the "clamped" intermediate/steering setup, while my '80-something setup has the bolt through both of them, with the nut on the other side.
    I guarantee that almost no car columns are a bolt up to a truck for one reason or another, I'd look it up in my Hollanders if I had it handy, but I'm 99% sure that no car is listed as an interchange. Of course, Hollanders will not show an interchange if there are wiring differences and what not. (so although it may physically fit, the wiring would be different, which is obviously not a big deal)
    I'm kind of surprised no one has chimed in and said "yes I've done it" here.
  11. grtwhite
    Aug 3, 2000
    366
    Macungie, PA
    Thanks for the help guys!! Maybe someone will chime in &amp; say this is what I've done /forums/images/icons/shocked.gif
