Steering column... call me stupid...
Discussion in 'The Garage' started by Grieby54, Jul 11, 2005.
  1. Grieby54
    Grieby54 1/2 ton status
    Jun 18, 2005
    782
    Houston, TX
    Is there any way to take the Auto shift thingy off a steering wheel column? I have a 77' pickup and I have an auto column but a manual tranny. I've been looking around for a manual column but haven't found any and I was wondering if I could just replace the part where the auto gear shifter goes in???
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    there is a pin that holds the shifter in placem knock or drill it out and you can remove the shifter. you will still have the little knob on the plastic there, but no shifter.
  3. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    its "possible" to replace that part, but not worth it (at LEAST an hour to tear down each of the 2 columns to get to that part) ... either live with the nub or get a manual column and replace it (less work) i got my new column for like $45 and its all of about 10 bolts to change a column (plus ignition cylinder and steering wheel) changing a column can also be a good time to add things like wiper control on turn signal arm, delay wipers, cruise control, tilt column, etc
    i suppose you could go after it with a saw and then bondo/plastic fill it back... but again, probably not worth the effort
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Used steering colum at "U-Pull It" back in Omaha were like $10.00 five years ago. I usely found them with the key, so I didn't have too mess with changing the ignition lock. Been a while sence I've had too change one out.
  5. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    i smoothed mine with a grinder then used jb weld to fill the hole and repainted it just be careful not to get the jb weld in there too far
    balzer
  6. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    that would be a nice score.. although 14bolt ff here are $35 all day long... a column with no key is $75 - with key - $100 - with key and tilt $150!!!!!! :doah:
    but I got my 85 jimmy with a manual column so will be going in in a few weeks :bow:
  7. Grieby54
    Jun 18, 2005
    782
    Houston, TX
    thanks guys... I appriciate the help
  8. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    exactally what we did, except we filled the hole with JB weld and than ground it down, it was pretty easy, after we painted it youd never know it was there
