Steering Column Coupler Where is it?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Kajun_K5, Aug 1, 2005.
  1. Kajun_K5
    Kajun_K5 Registered Member
    Jul 9, 2001
    48
    Lafayette, Louisiana
    I had the typical loose tilt steering column problem with my '86 K5. I took everything apart and tightened the 4 star head bolts as is traditon but know that the tilt section has been tightened I notice that the column is still moving. I looked at a diagram and the coupler is the only other joint I can see before the braces in the dash. I guessing the coupler is somewhere between the gear shift and the dash braces but how do you get in there?
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you sure its not the rag joint ?
