Steering column help
Discussion in 'The Garage' started by SUPER'BURB, Feb 28, 2006.
  1. SUPER'BURB
    SUPER'BURB 1/2 ton status
    Jan 9, 2005
    929
    Mountain House, Ca.
    I have a tilt column with an aftermarket steering wheel.
    The problem is this.....
    One of the 3 bolts that hold the collar (the part the wheel bolts to) stripped:mad:.
    I don't know what part I need or more correctly what it is called or where to get it. I am driving with 2 bolts holding it together:eek1:. It won't stay tight and it gets loose enough to feel every 3-4 days.
    Thanks in advance for the help guys:wink1: .
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Perhaps drill it out and tap it for a larger diameter bolt , of course that corresponding hole in the wheel needs opened up as well .
    Or maybe a heli-coil will fix it . Just like doing a waterneck hole on an aluminum intake .
