steering column interchangability
Discussion in 'The Garage' started by COCHEV, Mar 16, 2003.
  1. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    a guy in the paper is parting a 87 camaro and it has a good tilt column. with this work for my 90 burb?
  2. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    check out ebay. I bought my tilt for 50 bucks and it was from a truck. There are a couple on there now. Just search
    "chevy truck" and they should show up.
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    As long as it is the big round column, the car columns are almost exactly the same as the truck columns. Only diff is that the main electrical plug points the wrong way, and you can easily reroute it to work. I've installed several car columns in trucks...
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    BTW, even the square housings (which that may be, not sure) can be made to work by triming the plastic column casing where it hits at the dash. Takes a little work to make it look "not butchered" but I've used them...
  5. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    cool, thanks /forums/images/graemlins/thumb.gif he is asking $150 so i'll go check it out tomorrow.
    by the way, its an Iroc with TPI.......
