Steering column loose at tilt pivot!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Liberator, Oct 10, 2003.
  1. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    My steering column is loose and wiggles at the pivot point for the tilt. I have to wiggle the steering wheel to get the tranny in gear. It's on my '81 w/cruise. Is there an easy way to fix this? I was told there are three bolts that simply need tightening. The local wrecking yard offered to rebuild mine for $175 but I'd like to fix it myself if possible.
  2. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    yes,its just loose bolts...you do have to disassemble part of the steering column to get to them,and it can be tricky.if you feel up to it,get an exploded veiw of the steering column,and go at it. $175 for a rebuild is too much.i watched a guy do the repair in an hour,there are no parts needed,just some thread locker.if you cant do it,find a honest mechanic,and you will come out cheaper than that for sure.
  3. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Loose bolts or one of the tilt pins is working loose. Like the other post said use locktite on the bolts and quit grabbing the wheel and pulling yourself in when your getting in the truck, thats usually why the are loose.
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
  5. dyeager535
    26,979
    And to keep it from happening, do not use the steering wheel as a handle to pull yourself into the vehicle.
    Not saying you do (PO may have), but this is the cause of the problem. Cars use the exact same column and do not experience this "problem" with the column.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just get a column without tilt. That's how I fixed mine, it was too broken to repair.
  7. dyeager535
    26,979
    I was thinking about doing the same thing. No reason for me to have tilt, the wheel is always in the same position in my rig. Keeps others from driving it too.
    Then again, I'm not very big around the middle. /forums/images/graemlins/smile.gif (no offense folks!) People that share vehicles though, more than likely benefit from the tilt column.
    Personally, they all should have been telescopic, with tilt being the option on top of telescopic.
  8. bpiccioni
    bpiccioni 1/2 ton status
    Aug 11, 2002
    187
    Eugene, OR
    Are telescopic columns even available for trucks? The only telescopic column I've used was on a 65 Corvair that I helped a buddy drive up to Alaska. I agree, the telescopic column is really cool, especially when you wanna get close to the controls for that 'racing' feeling! /forums/images/graemlins/laugh.gif
  9. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    freightliner century class trucks have telescopic columns
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Dorian,
    The only major mod I would make to these trucks is that I'd make the seat go forward more than it does. I'm a midget and I really don't fit in them.
    I don't need a telescopic steering column. Hell, I didn't need tilt. I NEVER used it. The first day I owned my truck, I tilted the column straight and left it alone. I can't believe anyone would pay for such an option....
    Telescopic still makes more sense than tilt though. A smaller steering wheel might too.
  11. paveslave
    paveslave Registered Member
    Oct 11, 2003
    36
    Crestview, FL
    I had tilt/telescopic in a '72 & a '74 Caddy. I would think it wouldn't be a hard swap as they're both GM columns. I've never tried it so can't be sure.
  12. bpiccioni
    Aug 11, 2002
    187
    Eugene, OR
    So who wants to try it? /forums/images/graemlins/laugh.gif
    I need to tear into my column myself to figure out what's causing it's looseness at the pivot (probably the same loose screws as everyone else) as well as to install a new variable speed wiper switch w/ Cruise. The variable speed wiper is only variable in 1/2 mm adjustment range - I'm pretty good at working it, but it does suck, especially during monsoon season. I also have a phantom wiper while in first and occasionally during hard wheel tilts, so maybe some new wires to install as well.
    Problem is I dont have much fabrication experience or tools (welder, torch, etc) and I cant bring this pig out of service until I replace my 86 Jetta daily driver currently on permanent loan to my girlfriend.
    I'll be willing to offer moral support to someone else though! /forums/images/graemlins/laugh.gif
