Steering Column parts Swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by snoman87, Aug 9, 2005.
  1. snoman87
    snoman87 Registered Member
    Aug 25, 2004
    88
    Edmonton, Canada
    I have a Automatic steering column ... can I remove the automatic shifter part and replace it with the manual steering columns cover.
    How easy is it to tear these columns apart ... I have never attempted one ... any tips?
  2. mrk5
    Apr 20, 2004
    12,333
    1,043
    Northern Colorado
    I'm not sure if you can do that. Most people I've heard of just drive out the pin the holds the auto shifter so the lever is gone.
    I did some searching a while back here on CK5 for some steering column info and all the old links referenced didn't work any more.
  3. dyeager535
    26,979
    I've done it before, as a matter of fact took the "bowl" piece, and the ring that the shifter handle is on (or missing from in manual/floor shift apps) from a car.
    Only real issue is that for some reason I had to cut the hole out for the turn signal stalk out, as it hit when I tried to use the left turn signal. I think that had something to do with install or something, not parts differences. Not positive, there could be differences, but not sure why, all GM columns are essentially the same 70's-90's, very roughly. If they externally look the same, they pretty much are. :)
    Only real tough part I recall was pulling the pivot pins out for the tilt mechanism, you can either buy the tool to do it, or get creative and make your own puller. Lots of pieces in there though!
  4. snoman87
    Aug 25, 2004
    88
    Edmonton, Canada
    Hmmm ... as much as I would like it to look stock maybe that's a lot of work when I could just pull the shifter pin and go for a beer :D
