steering column removal???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Sep 17, 2001.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    How easy is the steering column to remove???
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    If you are talking about removinf the whole column it is real easy. Unbolt it at the firewall, gearbox, and under the dash, and it will come right out.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    2 on the box. 3 on the plate firewall cover. 2 on the bracket that holds the column to the dash(reinstall them with locktite). CAREFULLY disconect the wiring harnesses.
    <a target="_blank" href=http://community.webshots.com/user/thatguydrew23>http://community.webshots.com/user/thatguydrew23</a>
  4. reddog64
    Nov 9, 2000
    3,325
    anything to worry about with the shifter linkages??? and the wiring harness does completely disconnect correct???
  5. Anteak
    Anteak 1/2 ton status
    Nov 7, 2001
    105
    Hemet, Ca.
    I'm assuming this is to replace the column. If so, what do you look for in a replacement? Any GM as long as the length is the same distance of the one you are removing?
  6. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Shifter linkage on mine was a cotter pin and a stud. The litte indicater thingy was held on by a clip "doodad". Make sure to go thru all the ranges before you get on the road and see if they all engage and dont slip out.
  7. fr8train
    Aug 2, 2000
    1,712
    Maryland
    I would think that to be true as long as your staying within the full-size trucks, K5s, and subs. They should fit from 78-91 physically. The electrical acces. would be the only difference. That and the trim type.
  8. reddog64
    Nov 9, 2000
    3,325
    well i went to take it out... 2 bolts in side... 10 outside.... I have to take off the brake system on the firewall.. due to the shifter linkage on the outside end of the column.. it wont pull through the firewalll... any ideas???
  9. dyeager535
    26,980
    I believe rotating the column will give you some room to wiggle the shift linkage connection through the firewall...
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  10. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    There are 6 or 8 bolts that you access from the inside that allow you to remove the metal cover that is around the column. This way you don't have to worry about the shift linkage coming through.
    '85 K5 : Run it til it breaks, then fix it and go again!
