Steering Column removal
Discussion in 'The Garage' started by BowtieRed, Aug 30, 2003.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Ok, i took the steernig column hanger off right behind the wheel and the clamp behind the firewall. Do i now have to take the rag joint apart? and what about the transmission linkage? how do i disconnect it? sorry for all the questions, but i gotta get this SM465 in by tuesday.
    thanks all,
    Bowtie
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    yep undo the rag joint and disconnect the trans linkage where it connects to the steering column. There is a keeper ring on the back side. remove the keeper and push it out. Don't forget the wiring harness that is attached to the steering column.
  3. speed_deed
    speed_deed 1/2 ton status
    Jun 15, 2001
    947
    Valley Center KS
    I'm still in the process of switching columns for taking my SM465 out in favor of putting in a automatic.
    It's a pain in the a$$!!
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Why remove the column? Is it necessary?
  5. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    to accesss the pedal asssembly in order to attach the clutch pedal and master cylinder to the firewall the steering column must be removed.
    Now HOW do i remove the shift linkage??
  6. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    on the column(the end thats through the firewall) u should see a long shaft coming from underneath the truck up to a little arm on the column. theres just a litle cotter key you pull outa there and thatll take it right of. and if you want to take the rest of it off there is a bolt that holds that long shaft to the other arm which connects to the tranny. not much to it really.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Ahh ok hydro clutch I see now.
    Yeah it's easy the rod is right on the outside of the column near the firewall. You'll see it, it's cake to remove.
  8. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i see the rod, but i have to remove the arm that pushes the rod to get it through the firewall. and the rag joint isn't going to fit through either. HELP i'm doing it right now!
  9. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    HELLO!? HELP!
  10. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    You need to remove about 10 bolts on the plate that seals the fire wall up. Once you do that, there will be a big opening and the column will easily fit through it.
  11. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    I'll elaborate a bit.
    Pull back the carpet and then remove any insulation around the base of the column right at the firewall. You will se an eliptical piece of metal about 10 inches by 6 inches (that sounds familiar /forums/images/graemlins/wink.gif ) remove the bolts, 10mm I think, and the whole plate will come loose from the firewall. It will come out with the column. Once you get in there, you'll see how easy it is.
    Good luck
  12. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    THANK YOU SO MUCH!
  13. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea..lots of little hidden things but all in all its pretty sinchy..
