Steering column steering shaft
Discussion in 'The Garage' started by az-k5, Dec 30, 2004.
  1. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I found my steering shaft moves around and is completely loose, as it enters the column on the engine side. I have read/heard there is a bearing/race in there. How hard is this to replace. I would like to avoid replacing the column if posssible. It is just a simple no tilt auto column. I searched and found a part number in this thread. Is this the part I need? Should I just find a used column to swap?
    BTW I am trying to avoid chaning columns if at all possible. Nothing speacial about this one I am just lazy about some things.
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    Why not swap in a U-joint shaft? I found one out of a Jeep Cherokee that is really close to the right length. I plan on swapping it sometime soon. There is a member here that sells them for $75 or so too...BOWTIE I think.
    Rene
  3. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    If it is just the lower column bearing, they are not hard to do. In your vintage, there should be a wire-type retainer ring around the O.D. of the column, then a little metal cap, then work the bearing down and off the shaft. Retainers vary, but take a look at what you have, it's pretty self-explanatory.
  4. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Thanx nick, that is how mine looks to be. I will probably just do the bearing then.
    Rene, what kinda jeep did you find the shaft in?
