Steering column swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazer1978, Jul 8, 2005.
  1. blazer1978
    blazer1978 Registered Member
    Jul 8, 2005
    7
    Montreal, Quebec
    I have a '78 which got a 700R4 swap. Being that the orginal column is a 3speed auto....which model Chev/GM can I get a 4 speed column from to a direct fit?
    Same issue with the speedo.....new cable required to hook up to stock guage?? :rolleyes:
  2. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    I could be wrong but, most GM will bolt up. Only thing might be CC,turn signals may be different.
  3. sweetk30
    Nov 1, 2004
    25,543
    539
    horseheads , ny 14845
    from what i have been told thay are the same. the detents are in the tranny . a gm truck friend of mine does this all the time. he just swaps the indicator and it works good. havent tryed it my self.
  4. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    I was just about to post this same reply. There column is the same, the only thing you need to swap is the indicator if you really need to see what gear you're in.
  5. blazer1978
    Jul 8, 2005
    7
    Montreal, Quebec
    OK....sounds pretty good....so my problem my lie then with the fact that the shifter rod isn't properly attached to the shifting sleeve under the hood. (kinda loose). I'll pick up a real one (this is a mok up from the previous owner) and try that out.
    I may end up putting in floor ratchet shifter...unknown right now but thanks for the advice.....
  6. utchev
    utchev Registered Member
    Aug 17, 2004
    91
    Salt Lake City.....
    I'm using the GM column and shifter in my YJ (took the GM firewall plate off and used the Jeep one--looks factory). Should be a no-brainer in your K5.
