Steering Column Swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Uncle Fester, Jun 22, 2006.
  1. Uncle Fester
    Uncle Fester 1/2 ton status
    Mar 23, 2006
    229
    Cheyenne
    Hey guys, I am thinking about upgrading the steering column in my '78 Suburban 4x4.
    My truck is a floor shifted (SM465)truck, so do not need a shifter, but I want to have the headlight switch, turn signals, and wipers on the column. Right now all my switchs are on the dash except the turn signals, and I would like them on the steering column...any suggestions as to what year steering column will fit and give me what I want?:confused:
  2. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    82ish and up, I think, should give you what you want. Keep in mind that you will have to do some re-wiring when you put in the new column to control your wipers and your headlights. Not sure how to do this as I thought about it at one time then decided it would be easier just to leave everything alone in the end.
  3. dyeager535
    26,977
    Actually I think it's '84+ for column mounted wipers/headlight dimmer.
    My '83 wasn't, so I know you'd want something newer.
    Plan to spend time re-wiring stuff, as the column plug wiring changed.
