steering column wiring?
Discussion in 'The Garage' started by Frogg89, Feb 9, 2003.
  1. Frogg89
    Frogg89 Registered Member
    Jul 29, 2002
    85
    Southern NJ
    I need to replace the switch that my turn signal lever plugs into. I see that it has a small wiring harness going down to the base of the column. I also noticed that its all one piece. Does anyone know what this whole part is called? Ive tried stores and a dealer and they dont know what Im talking about. My blazer is an 89, so the problem is that my wipers wont work because this part froze up. If I had a name, maybe someone would make some sense of it.
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Its called the wiper switch. Tilt/non-tilt and delay/non-delay make a difference. You don't have to buy GM... jobber is available.
    Here's a pic of one for tilt & delay:
  3. Frogg89
    Jul 29, 2002
    85
    Southern NJ
    Thanks, thats exactly what Im looking for. They do make that aftermarket? Another quick question, Its a bitch to install isnt it??
  4. u2slow
    May 9, 2001
    2,217
    BC Canada
    Niehoff and Standard are two brands that carry it locally - but that's here in Canada.
    As for difficulty of install... depends on who's doing it /forums/images/graemlins/grin.gif Pull a string in as you pull the old switch out, so you can pull the new one in.
    You can check out a play-by-play right here:
    webfolder
