steering column
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by inaminute5150, Apr 22, 2003.
  1. inaminute5150
    inaminute5150 Registered Member
    Apr 16, 2002
    15
    west coast California Vacaville
    Do anyone have or know where to find a diagram of replacing steering column in an 89k5?Need to replace and chilton or haynes are no help desparate,also did search no help either!/forums/images/graemlins/1zhelp.gif
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Replace entirely or repair?
    For replacement...
    Disconnect the steering shaft from under the hood. Disconnect the trans linkage (if auto) - also under hood. Undo 4 or 5 bolts that hold the "foot" of the column to the firewall. Undo the trim that fills in the dash under the steering column. Undo metal portion as well. Remove vent duct (if AC). There will be two large nuts (one on each side of column). As you remove these, the column should drop. Disconnect the harnesses. Also disconnect the shift indicator clip (if auto). It should pull right out now.
    This is the 2 minute version of what I remember... it should account for 80-90% of the job.
    For repair.... its easier to show than to explain
    pics
  3. inaminute5150
    Apr 16, 2002
    15
    I need to replace entirely /forums/images/graemlins/k5.gif
  4. inaminute5150
    Apr 16, 2002
    15
    Curious . What tool was it that you used to get the locking mechanism back on,sure wished i would've had one while working on my column, after while the hand muscle just starts to cramp up /forums/images/graemlins/shocked.gif
  5. dyeager535
    26,979
    Lock plate compressor, usually cost about $10 at chain auto stores. Well worth the $$, even if you use it just one time, especially after trying it "manually" once. /forums/images/graemlins/smile.gif
  6. inaminute5150
    Apr 16, 2002
    15
    It is definitely worth 10 bucks even if not used at all! my hand will seocnd that notion.Thanks for info /forums/images/graemlins/thumb.gif
