Steering columns interchangeable from what years?
Discussion in 'The Garage' started by dremu, Feb 8, 2011.
  1. dremu
    Feb 27, 2000
    15,713
    95
    East of San Francisco
    Can I use an 81-91 column on my 73-80 truck? I know the box changed, but is the fitting on the end of the column that goes onto the shaft the same? Any other changes?
    -- A
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,161
    Sacramento, CA
    I believe you can interchange.
    The connection between the shaft and the column is the same I believe, it's different at the box side.
    I will confirm tomorrow I have a 76 and an 83 sitting in the back yard.
    Too lazy to do it now.:popcorn:
  3. KansasTwister
    KansasTwister 1/2 ton status Premium Member
    Jun 19, 2009
    2,733
    Lawrence, ks
    i know 73-83 had floor mounted dimmers and 84-91 had column mounted dimmers and wipers
  4. 1BEATK5
    1BEATK5 1/2 ton status Premium Member
    Dec 15, 2005
    2,715
    9
    beaverton orygun
    nope. there are 3 different lengths/columns from 73-87. i have been threw this with my brother's 81' but i dont remember what the years where.
  5. 4X4HIGH
    Dec 14, 2001
    21,985
    24
    Pleasanton, CA.
    As far as the connection between the column and the steering shaft there are 2 different ones and I believe from 73-79ish are splined on the steering column end and then 1980-1991 are double D style. There is also wiper/hi beam on column or on dash.
  6. pblaze725
    pblaze725 build bash rebuild Premium Member GMOTM Winner
    May 28, 2007
    4,029
    122
    Dallas
    I had to pull one out of the junkyard & I learned a bit via trial & error.
    Check the wire harness to make sure the wire colors match, also check the turn signal & tilt to make sure it's the same. The first one I got didn't exactly match & I had to take it back. The second one I pulled was close enough that I combined parts & made it work.
  7. dremu
    Feb 27, 2000
    15,713
    95
    I forgot about the high beam switch.
    And you know, I've seen the shorter column, but I thought it mighta come from a car or something.
    So, duly noted, measure and watch for electrical configuration. Thanks guys!
    -- A
  8. RootBreaker
    RootBreaker 1/2 ton status Premium Member
    Nov 29, 2001
    4,837
    19
    Williamstown, NJ USA
    well i put a 1986 (or 85 forget). fullsize gmc jimmy steering column in my '78
    really it all worked great.. only thing i had to do differently was take the wires from the floor dimmer and move them to the column. Since i had the other truck i cut all plugs to keep connectors...
    then for a few years i had the wipers working but not the squirters.... seems that the squirters just simply ground the hot through it and wheni rewired with the ez-wiring kit.. now they work...
    all this to tear it back apart and stuff into a 1980 k30 crew... (yup bankin on that WA crew!!!!!!!!!!)
  9. onetonbb74
    onetonbb74 1/2 ton status Premium Member
    Dec 1, 2005
    2,083
    Campbell, CA
    the high beam switch is easy, the wires from the column reach the floor if you need to re-wire it.
  10. RootBreaker
    Nov 29, 2001
    4,837
    19
    some would say this is a minimal upgrade... i personally will never own another old school chevy with the old column.. i love the wipers and highs on the column.. simple but nice... :thumb:
  11. 82355
    82355 1 ton status Premium Member GMOTM Winner
    Feb 4, 2009
    12,434
    724
    Bradish Nebraska
    I was looking at a 1973 C10 the other day that had the new steering column it it. The wipers and high beam switch were still both in their original locations and functional.
    Martin
  12. RootBreaker
    Nov 29, 2001
    4,837
    19
    cuz they were too lazy to run the wires.. :whistle:
  13. 82355
    Feb 4, 2009
    12,434
    724
    Bradish Nebraska
    I am well aware of that. I was saying it can be done.
    Martin
  14. RootBreaker
    Nov 29, 2001
    4,837
    19
    oh dont take me wrong.. i agree.. it just sounded a like i was disagreeing.. :haha:
  15. pblaze725
    May 28, 2007
    4,029
    122
    Dallas
