Steering correction after a lift installation
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudzer, Mar 24, 2000.
  1. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I have been driving my Blazer for several years after installing my 4" lift. I noticed from the beginning, after installing the lift, I can turn sharper to the left than the right. In fact when turning right at a stop light, in most cases my Blazer takes two lanes. I am wanting to finally correct this problem. Could someone explain how to adjust the drag link to cure the problem. I already have the raised steering arm that is sold with most 4" kits. Thanks.
    <font color=red>Mudzer</font color=red>
    1978/91 K5 Blazer
  2. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    Installing a raised steering arm should solve most of your steering problem. Also, you can add a dropped 2" draglink which will help a little but the arm would be the first thing I purchase.
    BTW-
    If anyone is interested, I do have a Superlift dropped draglink for sale. It's in the parts for sale board.
    Shawn
    87 K5
  3. When you turn one way the drag link is pushing and the other way it is pulling. It will loose that distance that it had when it was straight. The goal is to get the drag-link level so it pushes even and pulls even. Go with the 4-6" Arm for 54 bucks !!!
    [​IMG]<font color=red>BigBurb[​IMG]
    <font color=purple>IF YOU'RE SCARED, SAY YOU'RE SCARED !!
  4. Mudzer
    3,639
    Missouri
    I have the 4" arm that they sell with most kits. I think I need to adjust the draglink? Not sure..
    1978/91 K5 Blazer
  5. Yup, you're right !!!
  6. charliel
    charliel Registered Member
    Feb 27, 2000
    15
    Florida
    I'm in the same boat you are. I took mine to a shop and the tech told me the pitman arm needed to face 90 degrees from the frame...like stock. He suggested I adjust the adjusting sleeve on the draglink to compensate. You can only adjust it so far though. Seems the raised steering arms should compensate for this but they don't.
    77 Jimmy High Sierra
  7. Tommy
    Tommy 1/2 ton status
    Feb 21, 2000
    260
    Alabama
    I have the same problem, but my left turn is shorter. I have screwed the draglink in as far as it will go, I guess I'm gonna have to cut some off the ends of the tie rod ends so it will shorten a little more.
